22350 gallons,
TF-100 test kit
chlorine level kept between 1.5 and 3.5. Never been below 1.
No CC levels. Zeosand filter.
CYA level of about 25.
TA of 70
CH of 200
PH varies from 7.7-7.8 during the day down to 7.4-7.5 at night when the pool is not running
Currently using CALHYPO tabs not to raise the CyA.
I also add liquid chlorine to “help” the tablets if we get a big rain.
I check chlorine levels morning and night.
Pool was opened 1 1/2 ago with fresh water.
So Inlook on the edges, between the wall and the pool floor, and there is green algae growing there.
First time it happened was after a heavy rain.
I shocked the pool to 10ppm and kept it there for 2 days.
2 weeks later, a little algae shows up in the same edge again. I brush it and raise chlorine to 5 ppm. Kept there for two days.
A week has passed and today I find algae on the same spot.
I also have a PHin monitor that tells me the PH and ORP throghout the day.
ORP has always been in the mid mark.
So, all my readings are always great and have always been.
I barely have CYA levels in my water.
And the algae is showing up.
Many ideas why?
today I brushed it again, tested chlorine again. it was 3ppm.
So I added a Poly60 algaecide.
According to instructions, initial dosage is higher, than just add a bit every week for maintenance.
As soon as I added it, my ORP dropped significantly, almost reaching the lowest allowable level for balance.
So I heard that the poly algaecide combines with chlorine.
I added 1/2 package of CALHYPo shock.
I will test chlorine when I get home after work.
And test CC levels.
I am sure I will get it balanced again, but I just don’t understand why is there algae growing in the pool to begin with.
from what I heard and read about, algae should not develop on a perfectly balanced pool.
And I have kept my pool balanced since I opened it.
TF-100 test kit
TA of 70
CH of 200
Many ideas why?
And test CC levels.
