- Jul 10, 2023
- 29
- Vinyl
- Pentair Intellichlor IC-60
Not sure the best location for this but related to balancing the pool water. As mentioned previously SWCG installed ( w/new liner) recently so I’m in the process of getting it dialed in. Had the pool perfect until we went on vacation. Came back a week later to clear water but juuuuust tad of algae noticable when I went to brush up the bottom. Figured it was my fault for maybe not elevating the chlorine….or whatever. Had the pool for years and it happens when you’re away. …but then I noticed the pool light was almost full of brownish water and it had not been prior to vacation. Or I didn’t notice it. It‘s the original bulb not an LED unit. Surmising that when they replaced the liner they cracked the light and water seeped in and turned green. Pool place has accepted responsibility and agreed to replace it. I’ve told them we’d just do it at the end of the season but got to thinking. If water seeped in and stagnated, algae probably migrated into the pool and MAY be the cause of my pool beginning to turn and unless I replace it now, I’ll be chasing algae for the next two months. Thoughts?
