Hi all,
Been a lurker here for over a year, with lots of valuable info shared, but I have some questions... first off, I have a “temporary” wal-mart - 4’ deep x 14’ wide - summer waves pool hooked up to an Intex sand filter.
Never once had an issue with algae - but this past week, I was noticing a bloom starting. This, after I realized the pump has not run in two days after a brief power outage in Sunday tripped the power to the house and such, blew the GFCI. .. Doh! Pool temp is sitting at 87 degrees. Here are other relevant pool stats..
pH - 7.5
Alkalinity - 90ppm
Total Chlorine - 4ppm
Free Chlorine - 2ppm
So, tonight I decided to shock the pool. First, I got in and scrubbed the algae off, then vacuumed it and back-washed and rinsed the sand, and then I used Power Powder Plus from Leslie’s Pool as it has done me good over the past two years.
Tonight, about an hour after shocking, I notice what appears to be a brown film like substance (looks like pool filter sand, but isn’t) on the bottom of the pool. Is this from the shock?
Curious, beyond this, given it’s a “seasonal” pool, what else can I do to keep algae at bay? More chemicals?? Drain, clean and refill?
Thank you.
pH - 7.5
Alkalinity - 90ppm
Thank you.
