Air leak and equipment
Jimrahbe
22,847
Bedford, TX
Or a place for air to leak in... :mrgreen:
I had just never seen that before.. We do not close our pools down here..
TRUK71
156
Indianapolis, IN
Fiberglass
Jandy Truclear / Ei
I've actually took that one apart and rethreaded it with plumbers tape. That is one im sure is ok.
TRUK71
156
Indianapolis, IN
Fiberglass
Jandy Truclear / Ei
Builders came out and tightened down the 6-8 nuts that connect the 2 halves of the pump. They were loose. Bubbles have went away. Now to figure out why the blue pool is turning white.
fOxdiddy
5
Ottawa, ON
The liner? Or the water?? If it's the liner, your chlorine is set waaaay too high? Are you super chlorinating 100% of the time?
TRUK71
156
Indianapolis, IN
Fiberglass
Jandy Truclear / Ei
I don't have a liner. Fiberglass. 99% sure it's calcium scaling. Nothing to do with chlorine.
