Hello All
I have a recently installed in-ground pool L shape roughly 35k gallons. I have a Hayward Tristar VSP 950 with a 500 lb. Hayward Sand filter. The pool has 5 return jets and 2 skimmers with a slide, water fall and 4 deck jets. I have noticed I am getting air bubbles in 3 of the 5 return jets. There is 1 that is really bad and the other 2 are mild compared to the 1. I have researched possible causes and most sources say it is a suction side leak causing the air. I have checked the pump lid/basket, all suction side lines and have not detected any air getting into the system from the suction side of the plumbing. When the pump is running there are no bubble in the pump basket but the jets still have air bubbles. I decided to plug the one jet with a plumbing plug to see if the other jets bubbles worsened or stopped and I noticed that the air seemed to be coming from behind the jet (see pic/video Return pic/video). Can anyone provide any information of the potential cause? My pool water does not appear to be leaking down so I do not suspect an underground pipe leak issue (although still could be possible). Any help you could provide would be greatly appreciated. I put the tape on the pipe joints to help try and isolate an air leak but to no avial the air is still coming out of the return lines. I've also tried soap and using a water hose stream to cover all joints, pump lid and drain plugs but still same problem.
