Hello i noticed that every time I vacuum the pool the pump loses prime about 1/3. I’m able to vacuum but I’m afraid this could damage my new Pentair super flow VS pump. I’ve check all the gaskets aswell as the vacuum hose and I can’t find anything wrong which makes me think that there maybe a problem with the suction pipe coming from the skimmer. There is not air if I don’t vacuum.
I don’t know what to do at this point. The skimmer to pump pipe is 1.5”. I don’t feel like going into the ground to fix this at this point but I wonder if I could do something to maintain prime while I vacuume. Maybe a wider hose or a shorter vac hose as the one I have is longer than needed by 8-10feet.
Fyi recently upgrade the pump to a VS pump but I had the same problem with the previous single speed.
