Morning guys. 24K gallon vinyl liner in ground pool. 1HP new at the beginning of the season Hayward 1HP pump and motor assembly. Also have a Sta Rite nat gas 333K heater. 2 skimmers. One in the deep end one sort of closer to the shallow end. Pool is overfull for a few days. Skimmers at different levels, not sure why One is a little higher then the other by 3 or so inches. .
Pump runs from 7AM to 7PM everyday. Every morning I check everything over before work. This AM, I saw a lot of air going through the pump. I left open the air bleeder on top of the filter for over 10 minutes. I opened up the pump and cleaned out a very small amount of debris. Checked both skimmer baskets, clean. Can't stop the air. It is pulsing out of the bleeder tube. Everything looks good so I am at a loss. I had 10lbs on the press gauge so cartridge filters seem good but I have not opened them yet.
What would cause this all of a sudden. The pool being overfilled? One skimmer is right on the mark the other is a little high. Where do I start? Thanks!!
Brian
Brian
