Air blower on spa just stopped working
Jul 20, 2018
1
NAPLES
We have a spa built into our pool, the type that sits above the pool and has a waterfall draining into the actual pool. We used the spa last weekend and the air blower was working fine. Yesterday I went into the spa while the kids played in the pool and it turns on fine and heats up but the air blower light turns on in the control panel but it doesn't actually turn on the blower for the spa. What should I check?
Welcome to TFP. You have an electrically powered air blower with a motor in it? You know what model? Any label on it? If you don’t know then post pics of your equipment pad showing it.
First thing to check is the circuit breaker that powers the blower motor.
Could be a problem with the switch you are pressing to turn it on or a relay if it is controlled through your automation.
Please create a signature with your pool specs so we know what you have.
First I would check to see if blower is wired to its own breaker and start there. And then check to see that you have proper voltage at the blower. If no voltage check the relay or switch that controls the blower. If you have proper voltage at blower then the motor in the blower may need replacement
