You’re on the right track! Almost to the finish line
Since u asked
How Clear is TFP Clear?
Also, about your filter- backwash when pressure rises 25% over clean pressure - whenever that is for u -
Example :
if clean pressure immediately after backwash is 20psi you would backwash @ 25psi
My clean pressure is 10psi so I backwash at 12.5 psi. It is different for every pool.
that little circle with the arrows on the gauge should move so u can put at least one of the arrows in the right place as a reminder. Also be certain that the gauge is working properly (when the pump is off it should be on zero) if not it needs to be replaced- they’re not terribly expensive. It should be removed for the winter to prevent damage if u close your pool.
tftestkits.net
About the steps-
How are they weighed down? Most steps/ladders need modifications & regular attention so they don’t become algae hotels. Any weights should be completely sealed to prevent algae from growing in them. Pics would help us give u some ideas on preventing future issues.
SLAM ON
