After SLAM- Maintaining
Ribbod
90
Marietta/ga
Currently performing SLAM to get rid of algae bloom... Prior owners left Cal-hypo but I finally used that all up... Investing in 10% bleach (HDX brand from Home depot) to finish up and maintain.
This is my question: Once the SLAM is complete and I pass all the criteria, do i continue to add bleach daily or can I rely just on my SWG to maintain the proper FC level? Really don't want algae creeping up again!
Mr Bruce
2,438
Greenville, SC
You want to test your water regularly to confirm but if the SWCG is sized properly for your pool and is set for a % and run time that makes sense, as long as it's not failing it should keep your chlorine up. I personally haven't manually added chlorine for a couple months now.
Reactions: Ribbod
Ribbod
90
Marietta/ga
Coming back to make sure Im on the right track and doing this SLAM correctly... I though i was sharing my pool logs, but not exactly sure how to do that... Numbers below (CYA 70)
6/28 1:31 PM - FC 22.0
Added 177 oz. of 10% LC
6/28 8:34 PM - FC 25
Added 88 oz. of 10% LC
6/29 10:15 AM - FC 22.5
Added 162 oz. of 10% LC
6/29 1:03 PM - FC 28.5
6/29 3:04 PM - FC 29.5
6/20 5:18 PM - FC 25
Added 88 oz. of 10 % LC
How long do I have to stay at SLAM numbers? I reached it twice today then it started dropping and I added more LC to bring it back up... Water is all clear now...
mknauss
23,294
Laughlin, NV
Read the SLAM Process. The three criteria for a successful SLAM are described.
In your Poolmath app, touch the Gear in the upper right corner. Go to Sharing. Select Link from Troublefreepool.com user profile.
Ribbod
90
Marietta/ga
Yes, I understand the criteria... My question is how long do i need to keep the FC at SLAM level? Does it have to stay at or above 28 until I pass the OCLT and the pool is clear? Meaning- i can't let it drop below SLAM FC?
Reference my FC numbers above...
Ribbod
90
Marietta/ga
latest number: 06/29 6:53 PM - 29.5 FC
This is the 3rd time FC is over SLAM level today.. If OCLT passes tonight and pool is still clear, am I good to let FC drop tomorrow?
