Hello Everyone !
Brand new to the forum and I am hoping someone can help me. So here goes my story.
Moved to SW Florida in February to a home with a new built in pool. The size is 12000 gallons. The pool was set up as chlorine. We had a weekly pool service come in to take care of the pool and at the time knew nothing of the chemistry of the pool. Tabs were not used. He used liquid chlorine on a weekly basis, along with MA. I had no problems with the pool as far as any skin irritation. Everything seemed to be fine.
In the beginning of August we decided to convert over to a saltwater pool thinking it would be better for our skin and less maintenance, according to what all of our friends were telling us. I had been in saltwater pools previously and had not had a problem with them.
So, the first week of August we had the saltwater system installed by Pinch A Penny. All seemed good the first week. I felt the immediate difference in the softness of the water. It felt good.
The following week our pool service company shows up for the weekly maintenance and decides to add another bag of salt to the pool as he felt the salt content was too low. This is when it all went bad. The next day I went in and had a immediate skin reaction. My skin was burning and itchy and a slight rash developed, a week later, I tried it again and it was still happening. The pool service came out again and said our chlorine was at a 8 and adjustments had to be made on the system. This was done and for another month the rash continued every time I went in the pool even though they said it was balanced which we backed up with pinch a penny. There were adjustments with ph etc but overall both stated they could not figure out why I was having a rash. We did find out the stabilizer was high so thought maybe that was it. By this time I could not longer take it and we decided to go back to the chlorine and get rid of the salt system.
Our stabilizer was about 160, and we had to get the salt out, so we drained half the pool twice and added fresh water and went back to the way we had it. Only problem is, the rash has continued with the same itchy burning when I get in and when I get out of the pool. We are at our wits end as to what is causing this. I went to the dermatologist who said it looks like eczema but could not tell me why. I can pin point exactly when this started which was when we converted the pool. We have since let the pool company go and purchased a Taylor K 20006 C test kit and back it up with Pinch A Penny testing. We are still using the liquid chlorine which he almost has to add every other day to maintain the chlorine and MA, balancing is crazy. We keep being told because it is a new pool. Hesitant to switch to the inline chlorine feeder with tabs as from what I am read the tabs will make the stabilizer continuously
So, I am left with, what is causing the problem. The pool company said perhaps there was a additive in the salt that caused the problem and it is still in the pool. They say however there salt it pure, so does Pinch A Penny. Neither have ever heard of a reaction. Soooo, we went back to Pinch a Penny this a.m. Our salt is reading 1200. We questioned why so high after draining half the pool 2 months ago. He said could be the liquid chlorine. I asked both Pinch a Penny and the pool service company what brand of chlorine they use, thinking okay, maybe this is the issue. Pinch a penny uses Allied and our pool company uses Odyssey in Tampa. Now even though we let the pool company go we have used the same chlorine from them since day 1. They left us a jug last week, so that has not changed.
Our pool is not in balance today, but wasn't bad 3 days ago when I was in. Balancing act every day between PH and TA.
Here are the numbers from today.
TC: 5.0. This is high was we just added in 2 days ago.
FC: 5.0
PH: 7.8 (MA added this a.m. to lower within range of 7.4 - 7.6
TA: 85
Calcium: 300
Stabilizer: 30 (this is low)
TDS: 2,000
So, if anyone out there can suggest anything that might be causing this rash and irritation, it would be appreciated.
FC: 5.0
TA: 85
Calcium: 300
TDS: 2,000
