Hello good folks,
I am considering making the switch to a SWCG. I currently have a Nature2 Fusion (tablet feeder and mineral sanitizer) which I do not use (it's basically empty and serves no purpose). I am 100% on liquid chlorine.
I have been reading up on SWCG's but have no direct experience with them. It is my understanding that I will need to replace my pump as well as add the SWCG. Not knowing a lot about how the system works, I am looking for advice on my situation....... I currently have a Jandy/Zodiac system and utilize iAquaLink (version 1). I control everything from my phone and/or laptop. It is nice having everything integrated together and would like to maintain this if possible.
My questions are as follows:
- Is replacing my pump required? My current pump is a single speed and is not very energy efficient. It is my understanding I will be running the pump more frequently with the SWCG and I will need a multi or variable speed pump.
- The Nature2 Fusion Soft (SWCG and mineral sanitizer) would be a direct replacement for my Nature2 Fusion. I could use only the SWCG side and leave the mineral cartridge out of the system. However, the reviews I've read have not been very good and even my current Nature2 has been somewhat of a PIA replacing O-rings, leaks, etc.. Any thoughts on this?
- I've read a lot of positive feedback on the Hayward AquaRite. I don't believe this will integrate into my Jandy/Zodiac iAquaLink system (please correct me if I am wrong). Does that matter? Is the SWCG somewhat of a "set it and forget it" or would I be making frequent adjustments and/or monitoring where it would helpful to have it integrated on my phone?
- Finally, if integration/automation is only achievable with Jandy branded SWCG, would you recommend the AquaPure or Truclear?
