- Jun 13, 2016
- 115
- Vinyl
- Pentair Intellichlor IC-40
The first picture is from above obviously, with the second picture showing the whole equipment pad. As you can probably tell from these photos, I have 3 pipes coming into the pad from the pool, the two skimmers and one from the two drains. Then I have four return jets - as you can see by what is leaving from the Intellichlor. My PB is only charging $150 to close the pool, but I'd like to be able to do it myself. I have the "bottles" for the skimmers and caps for the return jets. I've read the posts on closing pools, but it confuses me since those are usually related to systems with sand or DE filters, and multi-port valves.
What process would be best for closing (thinking of buying a cyclone to do so)? And, how would I best connect the Cyclone (or shop vac if you think that would work as well) to be able to blow out the lines?
Some initial thoughts:
- I could disconnect the Intellichlor since I plan to bring it inside anyway and get direct access to the pipe leading to the returns. I will then put a dummy in it's place. I would then be able to open and close the pipes one by one as I blow them out and put the caps on each jet.
- I will drain the pump and the filter by removing the plugs.
- Not sure how to drain the heater yet.
- Would I connect to the pump to blow out the skimmer and the drains (again I can use the valves and go one by one). But, how do I prevent the air from going through the filter instead of through the lines back to the returns?
- The PB closed it last year and did not use anti-freeze and I don't want to use it either.
- The water is currently halfway up the skimmers. It would be great if I don't have to lower it, but if I do, what's the best way to drain water from the pool given this set up (I had a leak last year so it drained "naturally"!)
- I have an autocover that I will use as my winter cover so I need that to be supported.
