- Jun 15, 2019
- 23
- Vinyl
- Pentair Intellichlor IC-40
Bought house almost two years ago with inground 20x40 vinyl liner pool that hadn’t been used in two years per seller, but I think it was longer. Had a pool guy out that quoted me $3500 for liner and opening. I did a lot of research and had a list of equipment at the time, but our house renovations spiraled and the pool went to the back burner. I know I need to get serious if I want to get it opened anytime this season but have some concerns.
The pool was built in 1970 with cinder block walls and some type of lightweight concrete floor. It had a sand filter which looked to be 20 years old. There is one skimmer and a floor drain providing suction and there’s only one return eye on left side a couple feet from stair side wall. There’s also a slide with a water line so I guess that would be my second return. All of these lines are 1.5” diameter. I calculated roughly 32k gallons for the pool.
I keep reminding myself that this pool ran for probably 45 years with a single speed pump and sand filter. That being said, I feel like for the size of the pool, the two suction and two returns at 1.5” pipe is not enough by today’s standards and will need to run long for proper turn of water. For same reasons I’m concerned a heater and SWG may not be very efficient. I still need to pressure test the lines, but either way wondering if I should consider replacement to two inch where I can reasonably dig up and replace. I don’t know if I’m over thinking it or if it makes sense. List of components I had come up with before is below, but not set in stone. You can see pool as it was when we moved in and after pressure washing and installing cover. If I can provide more info, just ask.
- Hayward HP21404T Heater
- Hayward PL-Plus salt water chlorinator and control panel
- 011018 Pentair Intelliflo pump
- Pentair Clean & Clear Plus cartridge filter. 160301 or 160332
