Re: adjusting the SWCG - what's
jblizzle said:
Usually a good idea to add a few ppm of FC before and after a party using bleach.
AAARGH! I missed the "after" part.
So we are going around this for our second lap now and apparently still learning. Last weekend the kiddies were all here and in the pool constantly for two days. I was smarter this time and convinced the boss of our pool service (the wife) to let me drop some extra chlorine in before the extravaganza. I added enough to bump it a couple ppm and DW confirmed to me we are "around 5-10 now" (I bit my tongue wondering why we are back to the old test, but figured that 5-10 was OK).
After the two days of bather load I asked, with no small curiosity, how the numbers looked on the pool. The answer was "perfect, but add some acid" so I did. Yesterday I asked about the pool numbers again and got that annoyed look...
Well, today I was just told that something might be wrong with the SWCG because for no reason the FC dropped from "perfect" to zero some time in the last few days...
I'm thinking that my mistake was not bumping the FC up again after the weekend? I'm wondering if I should hide the DPD reagent to "strongly encourage" more use of the FAS-DPD?
Just a check here... if I'm still missing something. I'm thinking that the swimmer load introduces biological materials in the water, stuff that can reproduce itself? The idea that chlorine only "goes away" for two reasons (sunlight and reaction with stuff in the pool) makes sense. So with the SWCG only set to replenish the loss due to sunlight there is a need to bump the FC when we know other stuff is going into the pool. The numbers "look OK" from a DPD test on day 1 or 2 after the swimmer load because with only ranges measured, the FC is dropping from the high of the range to the low and then into the high of the next range losing a few PPM each day but seeming like the change was only from high (5-10) to good (3-5) as the level is actually plummeting to zero?
With the SWCG only keeping up with sunlight loss and nothing keeping up with other loss am I correct that the loss will accelerate to zero?
The plan at this point will be to raise the FC to target, then do an OCLT to confirm we need to shock. Seems OK?
For the next pool party, I guess we bump the FC before AND after and see what happens?
