...so we are away for the summer and got a house sitter to care for our pool. My hope had been that by this point the chlorine would be running like clockwork and no worries. Instead I now get to hear what my wife says the house sitter sees... anyway -- just before we left it seemed the pool was not holding chlorine so I inspected the SWCG (it has never been cleaned since new) and all the plates looked shiny and fine (I assume that buildup is like a chalky white?) My wife said that salt was "fine" (and the idiot light was green too) so I figured OK. So we did one last shock before leaving. We passed an OCLT but then the skies opened and it rained like crazy. The last thing we did was pump 2" of water to get the pool below even with the coping.
The house sitter is also reporting we aren't holding chlorine so we had her shock and do an OCLT too. No over night loss and finally now... the low salt light came on. So today she added salt and now we will see.
I think the situation is clear? As the salt level approached the minimum but still "OK" the rate of chlorine generation dropped and we were not keeping up with the daily loss. The rain diluted the water more and the salt level went below minimum, so hopefully we just need to bring it up and all will be good again? I suppose there is no "right" answer but between the time since startup (3+ months) and the rain we just got to the point we needed salt - how often should we "expect" to be adding salt? It seems it might be better to keep it above some level vs letting the idiot light tell us we are not making chlorine now?
