Hello all, my pool has a Jacuzzi-like sitting area with 3 jets plumbed on an independent return line line. I have an idea of converting this into a spa by adding a venturi valve on this line right after the filter and where the lines split off between the main pool and the sitting area. Just wondering if this would give me the effect I want. I don't want to add spa jets because that would require breaking concrete and digging.
I'm open to other ideas on how I can achieve this, even if it means getting a secondary pump just for the sitting area/spa.
Thank you.
Thank you.
