Okay, So April 2019 we had Fiberglass Inground installed and love the pool, recently we have had older family member use the pool and they are having issues getting in and out without a grab rail. I know the pool is bonded as I watched and made sure of that. Well I need to add a grab rail and I do not plan to core drill or saw cut the cement deck. So here are my questions.
1. Install stainless grab rail using 4 @ 1/2" diameter cement expansion bolts.
2. Install a Polymer Handrail same mounting style, with expansion bolts in the cement.
My issue and or questions are as follows.
Without being able to bond the Stainless rail how much danger does this actually pose? Is the bonding required if mounting bolts do not go through the poured cement?
If I go Polymer, does that negate the need for bonding as it is non conductive material?
Thanks
John
Thanks
John
