Hi All,
I'm adding CYA to my fresh filled pool by using trichlor tablets and will then switch to liquid chlorine. I tested my water yesterday after about 1.5 weeks of using tablets and CYA didn't register (I'm using Taylor K2005). Then I read that it takes a while for the CYA to register. Why is that? and when should I test? Should I just assume that my Pool Math calculations were right even if the test is telling me otherwise?
I have overdone it in the past and I don't want a repeat!!
Thanks!!
Thanks!!
