What order and how far apart do you add stabilizer and chlorine? (Specifically using "shock"). I wasn't sure if it was dangerous to add together like other chemicals
Adding CYA:
To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and place in the poolside skimmer basket. For those concerned about suction flow to the pump, suspending the sock near a return jet or from a floating device will also suffice. Best never to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level. CYA test readings should show a rise in 24-48 hours, however some pools may experience a longer delay to fully register. Best to confirm final CYA in about 5-7 days before adding any more stabilizer/conditioner.
We don't put one chemical on top of the other, but if you are adding stabilizer via the sock method (see below), there's no wait time required. Get that sock going somewhere (return jet, skimmer, or elsewhere) and pour liquid chlorine slowly near a different return jet(s). Have a good day.
That makes a lot of sense, thanks! I will shock tonight and then monitor tomorrow and see what I am left with at night. I've only had the pool 3 weeks so the 3 pucks that never really dissolved havent added much. My test strips show no CYA (yes I know there is a better reco test kit but what I have for now, it definitely shows 0)If you were using trichlor pucks, you should have some CYA in the water already. If you've been using them all summer, you may be over 30 already. Each fully dissolved 8 oz puck adds about 14 ppm of CYA to a pool of your size..
You will experience some natural, slow CYA loss depending on sun exposure. Best practice would be to test CYA before adding.
Also, 3 ppm is a minimum. If you simply add enough liquid to get to 3 ppm in the morning, you are very likely to have very little if any chlorine the next day. You will certainly be below safe levels to prevent algae. It is pretty normal to lose 3-4 ppm per day of FC even with appropriate CYA levels, depending on sun exposure of the pool. I lose 4 ppm with my CYA in the 40-50 range because my pool is fully exposed to the sun all day.
You should be adding enough chlorine that you still have 3 ppm or so BEFORE you add each day. That said, you may be at 6-7 ppm immediately after adding and that is perfectly fine.
Also, if youi have very high sun exposure, you might consider going to 40-50 CYA. It will ultimately reduce your chlorine use.
Yeah, I have 2 other brand test strips as well that I tried just wanted to confirm that they all showed the same/similar reading in case one was off. I've read through the posts and know there is a recommended kit but I dont have it"Aqua Chek 7 in 1 test strips"
Is that your only method of testing your pool water chemistry?
Is it like this?You would be better off getting a drop based test of any kind than the strips. Can you find what they call a 5-way?
Then just add up the stabilizer you add to the pool as being the CYA level in the pool.
Have you read Guide for Seasonal/Temporary Pools - Trouble Free Pool
It's 2pm and the FC is at 4ppm ...considering it's been 0 every day for 3 weeks, infuriating me with shocking every single night then swimming in an non sanitized pool, this is quite exciting.That's one will work for you. Walmart may have a drop kit a little cheaper, but either is fine for your seasonal pool.
The important thing now, to prevent algae (green or cloudy) is to keep the FC around 3-5 ppm. Never let it drop below 2. Is it's bedtime and the FC is 3 as an example, you should increase it to 5 before going to bed. Or if you usually test in the morning and it's low, increase it. As long as you have a CYA of 30 ppm, an FC of 3-5 (even 6 or so) is just fine for the pool and swimming.am I supposed to add more tonight only if it drops below 2 when I test later?
Hi! So I've gotten down timing to put chlorine every 2nd night and it seems to be working. I missed Sunday night because of a large storm and when I checked in AM the FC was 0. It may have sat at 0 for like 8 hours. What would be the typical protocol next? Is it too late I've messed up the cycle and algae started growing during that 8 hour period? Should I do a super chlorination or use algaecide, etc. thanks again!The important thing now, to prevent algae (green or cloudy) is to keep the FC around 3-5 ppm. Never let it drop below 2. Is it's bedtime and the FC is 3 as an example, you should increase it to 5 before going to bed. Or if you usually test in the morning and it's low, increase it. As long as you have a CYA of 30 ppm, an FC of 3-5 (even 6 or so) is just fine for the pool and swimming.
We don't usually use the term "shock" here like you might hear in other areas because it gets misused a lot from pool stores, friends, and neighbors who just bomb/shock their pool with high levels of chlorine without proper measuring. You should have no need to "shock" a pool, and by that I mean increase the FC exceptionally high. In your small pool, if the water gets yucky, just empty it, clean it, and start over. It's easier for you. That seasonal pool link tells you all about it. But just maintaining an FC of 5 or so is not "shocking" a pool, and if you want to place the cover on at night, it's fine.
