I've seen it suggested in different places (e.g. Taylor test kit booklet) that you should not add the total amount of a given chemical to the water at once. (For example, add half the dose, then a quarter, then the other quarter, spaced out over time).
On this forum, I haven't seen any reference to the above technique... does anybody here add their acid, bleach, baking soda, etc. doses in batches, or just add the entire dose slowly at once into the tub?
On a side note, is it best to dilute all chemicals before adding them to the tub?
Thank you.
Thank you.
