Adding calcium
You have a vinyl pool. Why are you adding calcium?
I don’t know😆 I’ve been a pool owner for only 5 weeks and I’m trying to learn everything. Got the pool math app and it tells me to add calcium, as did the pool store about a month ago. Is it bad for the heater or anything if it’s not at the “right” level?
Heater. OK -- that is why it is best if you fill out a signature.
Is this a gas fired heater?
I swear I’ve filled out all my info, but people keep suggesting I add info, so I must be doing something wrong. Where is the signature? The box below pool info where you can free text?
The heater is a Rheem 206 LP
Reactions: jessab
pool math is telling me to add 22lbs of calcium hardness increaser
PoolMath is just a calculator. If you give it a target, it will tell you how to achieve it. It's important to not blindly follow its output. You need to have a basic understanding of pool chemistry and use PoolMath appropriately to achieve your goals.
Reactions: Mdragger88
Yes, of course. I have somewhat of a self-deprecating sense of humor and way of speaking. So while I do have plenty to learn about caring for my pool, I know to not blindly rely on an app. I’ll be sure to read through all the awesome articles on this site. Thanks for your input.
Reactions: pjt
If you are adding calcium chloride, follow up with a FC check afterward. Calcium chloride addition causes FC crash in many instances. Restore proper FC level with liquid chlorine.
