Hi All
My Tub has 2 - 2 stage 220 v pumps. I had previously purchased an Acura spa control which is awesome. My old control was acting flaky. i put the new one in, but I knew it is a singe stage pump control so I added a relay and operate it from the Aux button. All this should be great but something is wrong. again This is a two stage pump.
details as follows
I got a relay with a 110v coil. I connected the coil to the aux output so when I hit the aux button the relay fires. I wired the two sets of common contacts to direct 220 v power. Then I connect the 2nd pump to the relay. I made sure I was sending the 220 volt to the red and black. I connected the white to neutral, even thought I should not need it. When I test fired it all seamed well. But the pump motor started to smoke after I ran it a while.
Can you advise I what I missed in my jury rig?
thanks Dennis
details as follows
thanks Dennis
