Actuator
jw,
I have never heard of a bad actuator toggle switch.. :scratch:
You can replace the micro-switches, that often go bad, but somethings are just worth the effort and time required to repair them.
I only have one actuator, but when it goes bad, it is going to be replaced.
What model actuator do you have?
What makes you think the toggle switch needs replacement?
Toggle Switch Valve Actuator 1.jpgToggle Switch Valve Actuator 2.jpgToggle Switch Valve Actuator 3.jpgToggle Switch Valve Actuator 4.jpg
Looks like a Jandy JVA2444 Valve Actuator with a Pentair Valve.
The switch can be replaced if you can find the correct part.
The actuators look pretty old, so you might be better off buying new actuators.
  • JVA2444.pdf
What actuator should I buy? The one on the right is the one that doesn't seem to be working properly. The one on the left is on my other two diverter valves. Are there any quality aftermarket actuators or should I stick with Jandy?
Thanks for your help.
Shop around. Jandy, Pentair, Hayward, Intermatic are all the same quality.
For what it’s worth, when I did my custom automation system, I got TORK valves for two of my Jandy valves. They are less expensive than the Pentair/Hayward/Jandy offerings and as far as I can tell, they have the same electronics inside.
