Interested in recommendations for a pump/tank solution that will dose muriatic acid automatically.
Currently planning on using my extra OmniLogic smart relay to schedule run times for turning the pump on/off. There will also be an interlock with the flow sensor only to allow the acid pump relay to be on when water is flowing and scheduled. The schedule can be controlled via phone on the OmniLogic app. Looking at 15-gallon tank solutions.
Some background -
I have added borates up to 50 ppm to help with the upward pH creep from my SWG, pool feature, and spillover but still have to add acid very often for balance. Looking to automate the process I found that Hayward has the Sense and Dispense solution, but after reading around it appears to be not recommended due to how the sensing works. Found several threads on Stenner tank/pump solutions and found the Hayward pH Acid Dispense AQL-CHEM4-ACID pump/tank combo can be hooked up to any relay system similar to the Stenner. Stenner has a lot of pumps to pick from with a variety of flows, but what is a good balance of functionality and safety? Higher flow can allow for quick changes to quickly balance the pool, and require less runtime, but can be more dangerous if mistakes occur from what I gather. I understand large tanks can also be dangerous if all 15 gallons mistakenly get pushed into the pool. Also, note with the TOU(time of use) electrical plan I am on, I usually keep my daily pump usage to a 6-hour window most days.
Some of the options I am considering -
1. Hayward - AQL-CHEM4-ACID:
What are the pros and cons of the Stenner Classic Series Single Head Fixed vs Econ FX - Fixed-speed pump?
Any suggestions would be appreciated.
Thanks!
Some background -
- 32 gallons per day fixed flow rate
- The pump runs when powered
- 15-gallon tank UV resistant with mount & cover rain shield for pump
- 16" x 16" tank footprint
- 3 to 85 gallons per day fixed flow rate based on model
- 15-gallon tank gray UV resistant with mount for pump
- 20.5" OD tank footprint
- 7.4 to 38.8 gallons per day fixed flow rate based on model
Thanks!
