Hi All,
I have a bit of an antiqued system (working on an upgrade) - .75 hp jandy one speed pump and a STINGL box.
My pool is a 25k gallon plaster pool with raised spa.
My question is, the pump keeps cutting off from low pressure (thanks to the stingl box cutting it off)
it has trouble priming and the pressure on the stingl box reads anywhere from 1.4 hg to 3.0hg (mostly stays under 2.0 though)
The pump is on the way out - but my question is - what is an acceptable number from pressure that I should be seeing?
thanks in advance
henry
thanks in advance
henry
