- Jan 16, 2023
- 9
- Plaster
- Jandy Aquapure 1400
hi i was wondering you had any idea of what tools i would need to remove 2 stones from my spa coping so we can get access to the plumbing. I know i need to chisel out grout on top and sides but what would i use on the sides where the stone is mortared to the sides? i don’t want to accidentally crack the stone when trying to get it off.
Our spa return lines are leaking and this is the only way to access them. The flagstone is 2 inches thick. The stones lay on top and plumbing is visible underneath so hollow between outside and inside walls.
