Hello.
I am reading the below article and it says to "Clean and brush pool. Bring pool water to “shock” level and maintained there for 24hrs with pump running to be sure that there are no remaining algae blooms."
What does it actually mean to bring pool water to shock level? Is that the same as SLAM?
Thanks
www.troublefreepool.com
Thanks
Closing (Winterizing) Your Above Ground Pool
Closing an above ground pool at season’s end should be a fast and worry-free process. Learn the basics of above ground pool winterization in easy steps.
