About to start plumbing new pool install - vacuum line?
jimmythegreek
397
Succasunna, NJ
#1
Ive read alot of ppl on here still use their manual vacs at times, I only have the adapter that goes into skimmer to manual vac with, its easy enuff to add now. Not sure if you need a special vac hose or head to use w the vaclock type fittings or can I adapt the cheap freebee I got with pool kit. thanks
jblizzle
41,197
#4
You don’t want a wall suction in your family’s pool.
About Us - The ZAC Foundation
They can be perfectly safe.
That link does not go into any kind of detail as to what the circumstances were.
I have 1 and have tested putting my hand over it and the suction is easy to overcome ... because my valving is setup to never allow 100% suction from that port. Plus the entire point of the cover I linked to prevents access if there is no cleaner attached.
jblizzle
41,197
#6
Well of course we all want to be safe. But a statement such as "you don't want that" is not very helpful with nothing to back it up.
I don't need to know the horrific details, but would think knowing the chain of events could be very enlightening so members are aware ... you did not provide that.
Personally I prefer to have my suction cleaner attached to the wall so that I can still run my skimmer at the same time.
I have stayed at a Holiday Inn Express once ... does that make our credentials equivalent? ;)
