- Aug 5, 2013
- 220
- Plaster
- Pentair Intellichlor IC-40
Short Story: I had a house with a SWG pool from 2014-2016. Never had any issues. Moved into new house and nothing but issues and I'm about ready to just empty it and fill it with dirt.
Long Story: It doesn't matter what I do - everything is all over the place. I could have the levels "good" and then two days later they are all bad and the pool is turning into a swamp. I will tear down the filter and put in new DE and the flow is great and then a few hours later it is low flow. I still have this mottling issue - so maybe that is it?
This is precisely what happened today - tore down the filter at 10am and washed it down real good. Then recharged it with DE. It had great pressure coming out of the jets and now at 2pm there is almost no flow (visually and the IC40 reports).
Temp: 82F
Pump: 2100 rpm
At this point I am less concerned about the chemical levels than I am at the pool going from good flow to almost no flow within 4hrs. Filter 10psi started at 10psi and is still at 10psi but the flow is almost nothing now. Do I have a leak and once the pressure gets to a certain point the water flow drops and then I'm no longer filtering and SWG stops? Should I be doing a leak check on my pool? No leaks on pipes above ground. No squishy yard from water spots. Or maybe I should just redo all my pipes?
Yes, I know my TA is a little high, my pH a little low, and CYA a little low at this moment but I don't think this accounts for the flow.
TF100 | Pool Store | |
FC | 5 | 5 |
CC | 0.5 | 0.5 |
pH | 7 | 7 |
TA | 110 | 97 |
CH | 220 | 286 |
CYA | 55 | 55 |
Salt | 1900 | 1812 |
Phosphates | - | 0 |
Pump: 2100 rpm
