PoolMath needs to know pool volume, starting pH, desired pH and TA to calculate how much acid you need. If you are using the online version, TA is lower down.I don't see how to add two things into Pool Math at the same time. Is that what you're saying @Teald024 ?
The fumes aren’t friendly on the 32% MAYikes - the fumes are that bad??!
I had to step away from it a couple of times and clear my lungs when I used muriatic acid the other day pouring it into a measuring cup.Yikes - the fumes are that bad??!
I’m rather type A and like knowing I added the right amount. >.>Skip the cup, pour it right into the pool. slowly....
