Thank you for the info. I have the Aqua Logic not Pro Logic tho, are they pretty similar? It seems hard to find stuff online about Aqua Logic, most of the time the search brings up Pro Logic or Aqua Rite for some reason. I will further troubleshoot today but I think it was a little of a false alarm. Of coarse when the guy showed up all was operating properly, long story short he cleaned the cell, called Hayward for IT troubleshooting, Hayward confirmed board was operating properly, they both discounted the Aqua Check salt test strips and told me to go get an actual salt test done. I did and here was my results:
Aqua Check salt strips: 3400 ppm
Aqua Logic board: 2700-2800 ppm (jumping from one to another)
LaMotte Tracer: 2800 ppm (got this same reading from 2 diff pool stores, 1st was a local shop 2nd was national chain, on same type of device)
"Fancy spin tester" possibly the LaMotte Waterlink: 2400 ppm (Local shop)
It's almost funny how many diff readings I have for this, I mean how do you determine which one to actually go with? One guy did the LaMotte Tracer test when I went in the first store, as I was walking out I forgot I wanted to see my phosphate reading so I turned around and the first guy all of a sudden was busy so the next guy did the spin test and that's when I noticed the diff readings, 2400 vs 2800, all within 5 min of each other. I asked the guy to explain the conflicting readings and he just said "the first guy shouldn't have used the LaMotte Tracer, he should've used the Spin tester"....good explanation. Phosphates on spin tester was around 800 some and at the second pool store phosphates were 300 some with dropper test. LOL. I've read some threads on here that the phosphates are very debatable, I probably wont do anything with them. My goal is to put the least amount of chemicals in the pool as possible. This all makes me that much more thankful to do my own water testing, what a headache.
I've read pretty good things about the the Aqua Check strips. I know they have a +/- but to have a +/- 600 ppm is just completely unreliable and unusable. Their next stop is the trash can. That fancy spin tester is reading pretty low but overall I think I'm going with the LaMotte Tracer/Pool board since they are all in the same ball park and the board is the actual device I need to satisfy since it's reading the salt and producing the chlorine. I added 2 bags of salt and will see if the reading comes up on the board in the next day.
Side note the pool service tech that came out, which was a really nice ma'-n-pa' family owned pool service company (very nice and honest), basically said he thought the Hayward system is one of the better systems out and to go with the salt reading the board was showing. The guy at the 1st pool store all but said my set up was junk in so many words. I've read the Aqua Logic isn't great and has some problems but man its hard to know who's advice to take with this stuff.
