- May 3, 2007
- 18,071
- Plaster
- Hayward Aqua Rite (T-15)
Sorry to continue with this but you and Evan seem to be saying different things.
Good, that is what I thought. So then when I add acid each week, my TA will drop a bit but it should not increase on it's own correct? After many weeks of this, assuming no alkalinity to the pool, TA should continue to drop. So if I am not adding any alkalinity, would I not see it drop over time?
My fill water does add some alkalinity and increase the PH a bit so perhaps this is what is increasing the TA. Although it would seem that the acid dose would lower TA more than the replacement water would increase it.
This seems to be in conflict with what Evan said above that without aeration, TA will rise again. From everything you have said, it seems that once TA has been reduced it will not rise unless more alkalinity is added.
chem geek said:The aeration from the SWG is conceptually no different than aeration from any other source such as waterfalls, fountains, or an air compressor. Technically, it is a rather efficient form of aeration since the hydrogen gas bubbles are small and they contain no carbon dioxide in them (initially). In other words, I would not consider having an SWG turned on as being slow aeration. On the contrary, it is quite vigorous which is why most users with SWG systems find a rather strong tendency for the pH to rise.
chem geek said:for your question regarding having aeration happen quickly to prevent the TA from rising the answer is no. It does not matter how quickly the aeration occurs. The physical process of having carbon dioxide leave the pool water causes the pH to rise with no change in TA. It doesn't matter how quickly or slowly this occurs.
waterbear said:Are you aerating to outgas the CO2 and raise your pH? If you are not then the TA will climb back up when the pH rises and the carbonic acid converts back into bicarbonates and carbonates.
