A little confused, as usual
Schnozz
442
Charter Oak, California
I had the weirdest thing happen Sunday. My system goes on at 7:00 am everyday and runs for about 8 hours. (Overkill, I know. :hammer:) Soooo, Sunday morning I'm outside cleaning up bit and the pump kicks on as it should. After abut 30 minutes I think I'm hearing sucking sounds. I see the Weir door on the skimmer is vertical as if there's no suction flow and verify there is no water flow through the return eyeball back into the pool. I shift the Three way Jandy valves and can hear there is indeed air in the suction lines. Quick as a 67 year old can move, I get to the pump and see the pump strainer basket is bone dry. I shut-her-down, and take a breath. open the vent on the cartridge filter and listen to it re-fil. Then open the strainer basket a bit and fill it with water as well. I restart the pump and watch. I see some air bubbles pass through the strainer basket from the suction lines, but within in minutes, everything is back to normal. The pump shut down at 2:00pm, like normal, without any further difficulty...What could have happened overnight that would cause that to happen? Where should I look?:drown:
I had the weirdest thing happen Sunday. My system goes on at 7:00 am everyday and runs for about 8 hours. (Overkill, I know. :hammer:) Soooo, Sunday morning I'm outside cleaning up bit and the pump kicks on as it should. After abut 30 minutes I think I'm hearing sucking sounds. I see the Weir door on the skimmer is vertical as if there's no suction flow and verify there is no water flow through the return eyeball back into the pool. I shift the Three way Jandy valves and can hear there is indeed air in the suction lines. Quick as a 67 year old can move, I get to the pump and see the pump strainer basket is bone dry. I shut-her-down, and take a breath. open the vent on the cartridge filter and listen to it re-fil. Then open the strainer basket a bit and fill it with water as well. I restart the pump and watch. I see some air bubbles pass through the strainer basket from the suction lines, but within in minutes, everything is back to normal. The pump shut down t 2:00pm like normal without any further difficulty...What could have happened overnight that would cause that to happen? Where should I look?:drown:
Sometimes lots of waves in the pool made my weir door stuck. Kids like to make giant waves for some reason. 🤣 might need to trim a little off the edge that’s sticking.
Reactions: Schnozz and Newdude
You know, I did noticed that the floating duckie thermometer 🦆 was up against the front of the weir door and the skimmer basket had floated up against the back of the door. The strainer basket was actually holding the weir door up...(Closed?)
Maybe just several circumstances in a row made it happen?? Everything is A-OK right now...I'll keep checking..
Thanks for the responses
