Hello TFP!
We are about to break ground on a pool at a farm resort we are building in Bulacan in the Philippines and I am hoping to get some assistance with the unknown unknowns, of which there are a lot since this is our first pool.
Here's an early rendering from our architect. We like the design and the dimensions will be ~26' x 39' with an 8' x 8' spa and a Baja shelf that runs the length of the pool on the spa side.
Since it's a build in the Philippines, materials options and availability can be a challenge. That being said, there are pools everywhere (beating the heat is a way of life!) and they seem to work just fine.
From our contract, the plumbing supplies look like this:
As for the spa, the idea is to have eight jets and two different height benches at ~36" water depth, one at ~15.75 in (40 cm) and the other at ~20 in (51 cm). Please forgive my crude drawing:
Question: For the jets in the spa, what height should they be at? Should I stagger them so that they're not all at the same height?
We plan to go with a ceramic tile throughout the entire pool and spa. Definitely not going to risk glass.
Any input is welcome and thanks again for reading!
Plumbing System
- PVC Orange Pipe 1/2”
- PVC Elbow 1 ½”
- PVC M. Adaptor Blue 1 ½”
- PVC Tee 1 ½”
- PVC Ball Valve 1 ½”
- Neltex Cement 400cc
Swimming Pool Equipment and Filtration System (Made in the U.S.A.) - Hayward Brand
- One (1) unit Motor Pump (Super II Motor Pump 2.5HP) complete with Strainer Basket
- One (1) unit D.E. Filter Tank, Model DE72.20 complete with Pressure Gauge, Air Relief Valve, and Union Connector
- One (1) unit Blower 1.0HP
- Heater (?) - We're still trying to figure out the right heater for the spa but that's where we are at the moment
