Hey all,
First time pool owner so would really appreciate some advice on closing my pool. I have a 21 ft' round above the ground pool. Here are my main questions:
- Should I drain the pool below the skimmer? The skimmer instructions say to drain pool 6 in below skimmer, but I have read others who recommend attaching a skimmer plate and leaving the water as is. If I did buy a plate to put over the skimmer, then what about the eyeball where the water returns to the pool? Would I just remove that and plug the wall fitting?
- Do I need a special chemical kit for closing or should I just balance the pool with the chemicals I have been using? Then should I shock the pool with chlorine after that?
- How important is it to store the filter inside? I imagine it would be extremely heavy to move. Could I but a cover for it in winter instead, or even just leave outside uncovered?
- I've seen information about a pillow to put under the pool cover. How critical is this, and can I get away with just the cover that came with the pool?
