I have a AA infloor cleaner that I am struggling with keeping functional. Brand new gear rotating assembly. Lasted through last season.
Last season had some air trouble with a leaky leaf filter lid from a crack in the body housing, sucked in a lot of air and priming was miserable. Before winter rolled in, I cut it out and piped returns straight to pump suction in the time being, as this runs year round. Tried to get the system up and running this spring, could get it to cycle through the valves a few times and then gets stuck again. Any tips? I made sure both sides of the gears are free spinning and not bound up with the lock washers, can free spin and they spin on there own for a couple seconds. The right gears of the lock washers on it. The valve body is t-handles and probably original 2004 year. The housing in original. The lid is most likely original as well. The washers at bottom the housing was replaced with the new rotating assembly last year as well.
Could air burping through this cause some disruption of the gear sets and knock them loose? I will check and see through the lid and see if the impeller is spinning. I dont believe it every binds up. They arent complicated...so not sure what my deal is trying to keep it functional.
I noticed on my third time opening it up this spring that there is a 5-port cam in place in lieu of the 6-port cam....
vs what I would expect on a 6-port cam:
