If I had known a month ago what I know now, I would have drained it, scrubbed it, and refilled. At this point, even though it's green, I can see the bottom and feel like I'm close to a turning point. I've been in a constant SLAM situation. Thinking my CYA was at 40, I've worked to maintain FC levels between 16 and 20 for AL this time. Even when it's dropped faster than I can get to it, I don't think it's ever dropped below 6. With a CYA of 0 and a SLAM lvl of 4, seems like anything living in there should be dead by now. One change I am making is brushing the pool with a wire brush instead of the soft nylon bristles. In doing this I've found several areas of black algae that when I scrape the top off, a green cloud comes out from underneath. Took off all the pool fittings and return jets yesterday as well as pulled the pool light and scrubbed out the concave area behind it. Can't quite figure out how to disconnect the light yet and hope I don't light myself up in the process of figuring it out. Seems like floating in 8 feet of water and messing with electricity is likely to make me a contender for this year's Darwin award.
Sent from my SAMSUNG-SM-G870A using Tapatalk
