I would reconsider what your about to do. What are the stains, organic or metal? Determine that first.
Set a trichlor puck on the stain for a few minutes. Does it lighten or remove it? If so, then it is organic.
Take a handful of vitamin C tablets and put them in a sock and crush them a bit. Set that on the stains for several minutes. Does it remove the stain? If so, it is iron. Does it make the stain darker? If so, most likely copper.
Trichlor is very acidic. It will damage your plaster. It also adds CYA to your water. Do you have a complete set of test results from your test kit?
