What I did was look at the base demand test and worked backwards from that using Effects of Adding Chemicals to see how much pH rise you should get. But pH is a logarithmic function, not a straight-line relationship, so at best you get a close approximation. That's why I suspected the rise wouldn't be as high as you desired. But it's better to work up to a level, rather than try for a one-shot massive adjustment. As it says near the bottom of poolmath:
Now that you're actually on the pH test scale, things should go smooth. You probably won't need to use the base demand test again. Poolmath will do the job easier.
Finish fine-tuning the pH and keep the FC adequate for your CYA level. That's really about it. In a day or two, run the full battery of tests again and post the results. If something needs adjusting, I'm sure people will point it out.
