I have an issue I haven't found a good debug path for.
Polaris wheel revolution speed is good, screen is clear and backup is working.
I see it get stuck on walls it would normally climb.
When I pull it out of the pool (running) and apply a small amount of resistance to any wheel it has no torque.
Observing it in the pool finds no wheels spinning when one wheel hits the wall at certain angles.
Robot has no issue with speed on flat surfaces and will climb walls once it gets started, but it's the transition from flat to wall that is the issue.
thanks in advance for help
