The IC40 that I have was replaced in November 2020 through Pentair. Details can be seen in this post; Pentair IntelliChlor IC40 Fire / Burning. It is not covered under warranty.
So the cell is just about 8 months old and the cell light is flashing. I have confirmed that it is NOT generating chlorine (installed spool piece, added water, held flow switch down with pencil). I clean / check the cell every 3 months or so and there is no buildup. Basically brand new.
I reached out to Pentair to troubleshoot this and they said to balance according to the following details.
My details are as follows.
I know the TFP stance on phosphates and I have been following it for quite some time (maybe 2 years). So I don't test it with my kit at home and the local pool store doesn't even test for it normally (on demand only). But when they tested for it, it was greater than 1,000ppb. So in order to be within specifications for Pentair to hopefully have them assist further, I am in the process of treating phosphates.
Is it possible that the failure in November 2020 could have affected the control board? Is there anything else that I should look at? Voltages to the cell?
Pentair | TFP | Me | |
FC | 2-4 | 4-6 | 4 |
CC | 0 | 0 | 0 |
PH | 7.2-7.8 | 7.2-8.0 | 7.6-7.8 |
TA | 80-120 | 50-90 | 60 |
CH | 200-400 | 350-450 | 375-400 |
CYA | 30-50 | 60-90 | 70 |
NaCl | 3600 | 3,800-4,000 | 3,800 (tested a few days ago by local pool store) |
Phosphates | <125ppb | N/A | >1,000ppb |
