Hi,
I replaced an ageing SWG with a Zodiac TRi Ph which I am pretty happy with, I got the large model, the problem is it's too good.
It's summer here and with the timer set to 4 hours and the SWG output set to 60% the Ch level is creeping up.
The solution I was thinking of would be to run the pump for 4 hours but only have the SWG running for maybe 2.5 hours at 100% output but the timers only control on/off they don't seem to allow you to change the preset output level.
I don't have any external panels or controllers.
Do you think I could get away with running the pump for only 3hrs a day with the SWG at 100%, my slightly educated guess would be that my 1hp pump would probably filter around a third of the pool volume in that time.
I am thinking energy saving at the end of the day but if it would mess up the pool...
Cheers
Richard
Cheers
Richard
