Finally done with school for the year! Now I'm hoping to get this SWG figgered out.
It is a "Mineral Springs" unit. The control box says MS-11, but it also has a sticker on it which says AQ-RITE - X281 (Could that mean AquaRite?)
The cell says Mineral Springs Cell-15.
My test numbers as of this morning FC 0, CC 0, TC 0, pH 7.7, Alk 130, Cal 380, CYA 40, Temp 84 degrees, Salt (per Ben's drop test) 4000.
(I didn't add bleach yesterday)
My salt tests always ran 200-500 above what my digital readout ever said!
When I turn on my unit it initially reads Minerals 1800, V 23.6, amps 3.84, generating sanitizer (I have it set at 70%); but then the readings cycle down to 0 minerals, 30V, 0 amps and it says to inspect cell and check mineral levels. The cell is clean, there is no build-up. There was some crystals on it when I closed for the winter, but no recurrence this year.
