60% algaecide
Honestly, I would NOT order a test kit off of Amazon. Others have ordered from an Amazon seller and receiged outdated reagents.
Additionally, that tes kit looks to be a K2006A - the 'A' demoted the small reagent bottles. You will rund out of certain reagents quickly. If you are truly set on a K2006, get the K2006C - which has the larger reagent quanitities.
Any chance you can drive down to Buffalo or Niagra Falls NY?
You can order a TF-100 from TFTestkits.net and pick it up at a mail drop there.
Only if you also add the Taylor K1515C - which will make the K2005C / K1515C combo comparable to a K2006C.
The K2005C is missing the much needed FAS-DPD test.
Since you haven't responded to my question of a trip to Biffalo or Niagra Falls NY, I guess that's out of the question.
Sorry for not answering but yes it's kind of out the way
It's 0.75 oz bottles
In a pinch, you can use chlorine-free water (i.e. bottled, distilled or old tap) and dilute the OTO test 1 part pool water to 2 parts chlorine-free using an eye dropper or for more accuracy use a larger volume in a plastic bucket and weigh the water volumes on a kitchen balance. You can extend the range of the OTO test using this approach.
I order refill chems, in larger quantities than tftestkits sells, from Amazon all the time, I have never gotten expired chemicals.
