Can anyone anticipate how fast FC will deplete once it is brought up to shock level? I know a few things will determine this. I plan to start the shock process at night to get a good jump on it. so sun light will not factor in until the next morning. And I will monitor it every hour as late into the night as possible. But once I go to bed whats to happen to the FC level while I'm asleep? Do I need to wake up once an hour to test and adjust? I'm assuming once the sun is up it will state depleting at a faster rate.
I found a supply of 12% liquid chlorine which I will be using. I'm also trying to get an idea of how much liquid chlorine I should have on hand to maintain shock level until the shock process is complete. I've read somewhere it was like 4 times the amount it takes to bring to shock level. If that's the case, and it will take 2 gallons 1cup to bring to shock level, then I will need about 8 to 9 gallons to complete the shock process and kill all the algae. Does this sound about right?
