Thread: Just got new test kit. How do my numbers look ?
    May 2008
    Hockessin, Delaware
    46
    Pool is almost 2 Years old. Gunite Pool 19,500 gallons. Here is my first test results. Pool just opened 2 days ago. Water 60 degrees.
    Fc - 3.5
    cc - 0
    TC - 3.5
    PH - 8.2
    TA - 130
    CH - 220
    CYA - 20
    Salt - 2830
    21 X 42 freeform gunite pool w/ spa
    white plaster finish
    Jandy VS ProFlow Pump
    3 returns, 2 skimmers
    pentair DE filter
    Aquapure 1400 SWG
    Raypac 399,000 BTU Heater
    Zodiac Nature 2 Pool sanitizer (haven't used yet)
    Guest
    You might find this sticky on water balance for SWGs useful.
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Hello Gzelano
    Welcome to TFP,i am just a nebbie and want to help a bit. but the pool gurus will probally be here soon. Your numbers don't look to bad, you could bring your cya up a little, [ salt 2830 means you have SWCG??] if so about 50 - 80 is acceptable with an FC of 3.5
    Also looks like your TA is a bit to high as well, and seeing as the ph is up , it's a good opportunity for you to bring your TA down at the same time as well. Have look at this sticky in chemistry for a full explanation
    http://www.troublefreepool.com/viewtopic.php?t=5341
    also you could check your SWCG manual for correct salt level as you might have lost some in your last swim season. [ splashing or backwashing ]
    Also if you list your pool details in your signature it really helps the experts help you.
    anyway the pros will come along soon and help as well.
    happy swims
    Frankie
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Apr 2008
    Thailand
    152
    Told you the they woul be here soon , hey Bear shouldn't you be asleep its 2.47 pm here and its a 12 hr time diff
    are u dreaming pools or what.
    Anyway Gelzano this site is great and they do try to help everyone
    cudos to Waterbear and the rest of the team
    May 2008
    Hockessin, Delaware
    46
    Thanks, I updated my signature.
    pentair DE filter
    Aquapure 1400 SWG
    You want to bring your PH down. Try to keep PH between 7.2 and 7.8 at all times.
    CYA should go up. CYA between 60 and 80 is best when using a SWG.
    Then read the sticky waterbear suggested for the finer details.
