Trying to firm up my quote request to send out. This will be a DIY. Would really appreciate any comments or suggestions. Especially on the equipment and automation. Thanks
Pool: Hydra Vinyl Pool (<20,000 gal) max depth 5'. Still debating shape with the wife, she'll eventually win but I have to resist for a while.
Wall Accessories: 1/8" Foam, 2 Adhesive & Tape
Brace System: Polymer-X-Braces
Coping: Cantilever-forms-steps
Shallow End Steps: R-8-White_Sit-n-steps
Step-Location: Off-center
Handrail & Escutcheons: none
Straight end entry: In-pool corner step at 2R corner
Handrail: none
All plumbing to be 2”
Heater: Pentair Ultratemp Heat Pmp 120 Heat/Cool 125000/75000 Btu
Pool Pump: Pentair IntelliFlo® VS Variable Speed Pump
Pool Filter: Pentair Triton II TR50 (21") Sand
Pool Filter Valve: Pentair Triton Multiport Valve Kit 2"
Skimmer-System: R-2skm-3ret (2 skimmers, 3 returns, no main drain)
Chlorinator: Pentair Intellichlor Complete (Cell & Power Center) Up To 20000 Gal
Automation: EasyTouch 8 control system with Screen Logic (iPad, iPhone, & computer controlled)
Maintenance Kit: Basic
Auto Cleaner: Pentair Kreepy Krauly Legend II Pressure-side auto in-ground cleaner
Pool Light: Pentair Intellibrite® 5G Color Led Pool Light 120V 50' Cord
Pool Light 2: Pentair Intellibrite® 5G Color Led Pool Light 120V 50' Cord
2-way Valves: 3
2-way Actuators: 3
3-way Valves: 4
3-way Actuators: 1
Check Valves: 5
Hand-Curve: Right
Pool-Depth: Play_5ft-4in
Non Stock Liner: Siesta Wave 20M
Here is my plan for the equipment. I used a plan originally posted by VinceL as my guide, so many thanks to Vince.
Handrail: none
2-way Valves: 3
2-way Actuators: 3
3-way Valves: 4
3-way Actuators: 1
Check Valves: 5
Hand-Curve: Right
