I have a Raypak 206A heater which is just over a year old and no power.
Fired up the heater yesterday to bring the pool temp up a few degrees and I noticed the I wasn't getting any heated water. I went out to the unit and the display was blank like it had no power. I removed the cover and and made sure the connections(AC) to the unit were okay. Took a meter to make sure I had AC power and I was a little confused on what I was seeing didn't appear to be correct but I was rushing because it was beginning to rain. I may have had the wrong value selected on the meter. In addition I checked the power switch itself and it was good.
What I didn't do is check the other side of the transformer to verify 24VAC.
Has anyone else run into this problem. I picked Raypak for its reliability. If the board is toast I'm going to be upset.
