Thanks in advance. I keep getting algae. I use bleach to sanitize. Since I have a sand filter I have to vacuum to waste to get rid of algae. In my case this means practically empting out the pool. Which means I am literally starting over every weekend. I desperately need diection. I test almost everyday however the results are always high ph and in many instances high clorine. I shock and it does not remove the algae just brings the clorine levels sky high off the scale. I use the pool calculator to determine how much acid to bring the ph down. However the algae comes back and I start this crazy cycle all over again.
